12748 Discussions
NiosII_1c12 evalkit with examples on sound output
Hi everybody ,
I was very surprised to know the sound output port on NIOSII_1c12 EvalKit , which is a 4-pin port named J7 (assuming you installed NIOSII IDE in C , the document is in C:\altera\kits\nios2_5\documents\nios_cyclone_1c12_eval , file : Block_Diagram.pdf (at the bottom of the file) , Cyclone_Demo_Placement_Final.pdf (at the lower right corner) , nios2_evaluation_1c12_board_schematic.pdf (page 5 , 12) )
I would like to ask if you have any example projects (either from Altera or Microtronix) that outputs audio sound to the connector J7.
If yes , please show me the source or the URL for me to reference.
Thank you so much,
OneNet
Don't think anyone here has ever used it for sound. You might have better luck asking in one of the other forums...
