SIOCSIFADDR error
This is a custom board. I have taken everything out except for the Flash and SDRAM. It is actually a fairly simple system, flash, sdram, and an ethernet port. I don't use tightly_coupled_memory (have not familiarized myself with it yet), and my data cache line size is 4 Bytes, exception pointer is set to SDRAM.
I am out of ideas. I also can not load the kernel into RAM from the IDE, I'm forced to burn the Flash each time I make a change. I get the following message from the IDE console. Do I have a JTAG problem? I'm using a USB Blaster "Rev B".
Downloading 08000000 ( 0%)
Downloading 08010000 ( 6%)
Downloading 08020000 (12%)
Downloading 08030000 (18%)
Downloading 08040000 (25%)assertion "m_state == STATE_DEBUG" failed: file "nios2
debug.cpp", line 1695
Signal 6
Here is a copy of what I get when I launch the nios2-terminal. Most of the time I'm unable to log into the system, I usually get "Login incorrect." When I am able to log in, I usually get kicked out fairly shortly, and the system goes back to the login prompt.
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 1024 (order: 10, 16384 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory available: 128640k/131072k RAM, 0k/0k ROM (857k kernel code, 203k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Linux NoNET1.0 for Linux 2.6
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80000860 (irq = 2) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 2 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 52k freed (0x80f2000 - 0x80fe000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
SIOCSIFADDR=-1: 9
SIOCGIFFLAGS = -1: Bad file descriptor (9)
SIOCADDRT=-1: 9
Unable to create socket
close on exec: : Bad file descriptor
setsockopt: : Function not implemented
Unable to bind server socket: : Function not implemented
Unable to listen to socket
/etc/issue www.microtronix.com June 2005
Welcome to Linux on the Nios II
Nios2 login:
Any ideas would be great,
Doug
Doug,
Did you ever figure out your problem?
I am also developing a custom board. I also get the mysterious error:
assertion "m_state == STATE_DEBUG" failed file "nios2debug.cpp", line 1695 signal 6
What does this message mean? I just opened an SR with Altera, but have been stuck with this for a couple of weeks now....
My conditions are as follows:
I get this error just by reversing the order of how I open my tools. If I open a shell to load my hardware before opening IDE I get the error.
If I open IDE before opening my SDK shell I DO NOT get error. The result is reproducible with some of my boards. Other boards will hang with the message:
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
or not respond to further commands.
I am in a jam because my boards have been manufactured and assembled and are ready for production , and now this error shows up.
-Baycool
I am using Quartus 5.0 and Nios II 5.0 with a Full License for both
Baycool,
Nope, I never did figure it out. I do know that I can connect to my board through the ethernet port with out any problems. Everything works fine here, I can telnet in, ping it, and the web server runs just fine. I'm pretty sure this is a JTAG UART issue. I just don't know what yet.
I'm working on trying to figure this out. We got another custom board back late Friday. I will get that one up and running to see if the same problems arise.
I tried your trick of opening the IDE first. It still bombed on me.
I'll let you know if I find anything out.
Doug
Thanks Doug for your reply.
It is very consoling to see that I am not the only person suffering with these problems.
Last week I was so elated even to find a hit on my search for "m_state == STATE_DEBUG".
I get so many communications problems with the JTAG UART that this is an almost impossible problem to debug.
I tried a "grep" on the message in the entire /kits directory and could turn up NOTHING.
At the very least I would like to see this message in C source and atleast know for sure the cause of the problem.
By the way, do you even have an occasional comm problem with your ethernet port?
-Baycool
Baycool,
At this point, I can't isolate the problem, therefore, I can't say it is a JTAG UART problem, but I'm pretty sure that is the source of my headaches.
Up to now, I have not had any problems with my ethernet port.
Doug
