12748 Discussions
Problem about i2c driver and test
I add opencore i2c to Nios II, and tested by i2ctools under uClinux( Microtronix nios2linux 1.4)
1.
3 chips in /dev/i2c-0
_________ typical read (they are different)
EEPROM_: S Addr Wr [A] Reg_addr [A]______________S Addr Rd [A] [Data] A.......[Data] NA P
FRAM___: S Addr Wr [A] Reg_addr_H [A] Reg_addr_L [A] S Addr Rd [A] [Data] A.......[Data] NA P
Realtime : S Addr Rd [A] _____________________________________[Data] A.......[Data] NA P
2.
Here is the result of i2cdetect
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: XX XX XX XX XX XX XX XX XX XX XX XX XX
10: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX
20: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX
30: 30 31 32 33 34 35 36 37 XX XX XX XX XX XX XX XX
40: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX
50: 50 51 XX XX XX XX XX XX XX XX XX XX XX XX XX XX
60: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX
70: XX XX XX XX XX XX XX XX
which indicates the adress of them correctly:
EEPROM : 50
FRAM : 51
Realtimer : 30---37
3. problem
3.1
I see only "ioctl" in i2ctools. Could I using "read" "write" method? (As the compiler tells me errors in :
#include <linux/i2c.h># include <linux/i2c-dev.h>
3.2
How can I access 3-different types of i2c chips via oc-i2c drivers?
Could I modify i2c-oc.c and i2c-algo-oc.c to implement or add new 3 i2c-eeprom.c, i2c-fram.c and i2c-realtime.c ?
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
I see only "ioctl" in i2ctools. Could I using "read" "write" method?[/b]
--- Quote End ---
you can use ioctl to read/write those devices, the command you need is I2C_RDWR.
--- Quote Start ---
How can I access 3-different types of i2c chips via oc-i2c drivers?[/b]
--- Quote End ---
You can have different utilities. The device address is specified in the message passed with this ioctl command.
--- Quote Start ---
Could I modify i2c-oc.c and i2c-algo-oc.c to implement or add new 3 i2c-eeprom.c, i2c-fram.c and i2c-realtime.c[/b]
--- Quote End ---
If your kernel does not utilize those devices, you don&#39;t have to implement something in kernel.
