NiosII
hi
I have a source code of compression vidéo (h.264 ,jpeg) how is exécutable in visual studio c++,my problem is how to implement this code in NiosII ,how to convert this source code in niosII. thanks in advance.
hello there,
thanks for your time and support, i have send my email add through private message.
i hope you have got my ID by now.
thanks
hi kaushal, i send a source code in your email, to test this code you must have a visual studio 2010,build, génerer and debuger, i don't have a great gift idea about this code source
because I finally used a jpeg.
Hello Sinam,
I have a receipt of your source code,
Thanks once again
hi,
i have a project how is able to use a traitement of image, my problem is does not result the compilator stopped, my question is how to optemize the code ?
thanks in advance.
Hello Sinam,
Please clarify what type of "traitement of image,", i have previous experience of image compression in C and FPGA.
hi Kaushal,
the traitement is extract a matrice of covariance from the image, the problem is the capacity of memoire (SDRAM,..) because the size of image is very big.So question is how to optimize the code source,Or to accelerate it.
