12748 Discussions
No display in NIOS II console
Naccy
Hello all,
I tried the 'NIOS II Application and BSP from Template' using a previously developed sopcinfo file, but the NIOS II console showed empty.
Here's what it says in the console:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x10021980:
ID value verified
Timestamp value was not verified: value was not specified
Initializing CPU cache (if present)
OK
Downloading 08000000 ( 0%)
Downloading 08010000 (51%)
Downloading 0801F088 (94%)
Downloading 08020000 (97%)
Downloaded 125KB in 2.1s (59.5KB/s)
Verifying 08000000 ( 0%)
Verifying 08010000 (51%)
Verifying 0801F088 (94%)
Verifying 08020000 (97%)
Verified OK
Starting processor at address 0x080001B4
aikeu
Hi Naccy,
I do not understand your desciption regarding the matter.
May I know which document which you refer for your work?
You mentioned about no display but able to see the logs from the console.
Aik Eu
Naccy
HI Aik,
Previously, I tried several examples in order to have some basic idea about the NIOS II system development. Unfortunately, all failed.
Yesterday, I followed the steps from youtube: https://youtu.be/KjagfaiWuBM?si=cw8z-C7mycZCK3dy , when run into hardware, console did show me something, but NIOS II console totally empty.
What can I do for this situation? I dont think it is design or procedure issue.
Naccy
aikeu
Hi Naccy,
May I know what is the board which you are using?
I see that there is something is different from my side as compared to your logs:
Using cable "DE-SoC on 10.107.209.7:3589 [3-1.2]", device 2, instance 0x00
Pausing target processor: OK
OK
Anyway I suspect that you are using the wrong example project for your board.
Try to find an example project for the board which you are using for reference to run:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/design-store.html
Aik Eu
aikeu
aikeu
Hi Naccy,
May I know any further feedback from my previous respond?
Aik Eu
aikeu
Hi Naccy,
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
