- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
After I download the ucLinux kernel to the board (2S60) successfully. I begin on the filesystem project.
In the wizard, after project name setting, in the "filesystem Options", only ext_flash can be selected as the "Memory Device". Actully the onboard flash is 16M, but 0K is available appeared in target filesystem application selection. Even if I ignore the available memory warning, after build, the file system can not work. the error messege as follows: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.11-uc0 (Administrator@altera) (gcc version 3.4.1 (Altera Nios II 5.1 b73))# 16 Thu Jan 12 16:24:34 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 128 (order: 7, 2048 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 14592k/16384k RAM, 0k/0k ROM (1422k kernel code, 183k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x821208b0 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 100000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07: ed:0e:b0:63 smc_probe: 100000 Khz Nios Altera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bank Amd/Fujitsu Extended Query Table at 0x0040 Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using Altera NDK partition definition Creating 4 MTD partitions on "Altera NDK flash (AMD)": 0x00200000-0x00800000 : "romfs/jffs2" 0x00000000-0x00200000 : "loader/kernel" 0x00800000-0x00c00000 : "User configuration" 0x00c00000-0x01000000 : "safe configuration" NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 1024 (order: 1, 8192 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) NET: Registered protocol family 1 NET: Registered protocol family 17 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0) nios2-terminal: exiting due to I/O error communicating with target How can I resolve it? Regards YueranLien copié
0 Réponses
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
