12747 Discussions
Nois V Command Shell Error
HamzahS
I've implemented Nios V/g in Quartus Prime Standard Edition 23.1std. I want to create the bsp project using the following command:
niosv-bsp -c --quartus-project=TEST.qpf --sopcinfo=sys_module.sopcinfo --type=hal sw/bsp_custom/settings.bsp
I get the following erros:
Error: Unrecognized switch <b>quartus-project</b>
Error: Failed to validate switches.
I tried many forms of the command, but I still get the error.
Kindly advise on how to solve this issue.
Broddo
I've run afoul of this as well. There seems to be a discrepancy between the command-line arguments referenced in the docs, the commands that niosv-bsp claims to support and actually available in niosv-bsp.
The solution for now: try leaving out the --quartus-project switch. It's not necessary
niosv-bsp -c -s=sys_module.sopcinfo -t=hal sw/bsp_custom/settings.bsp
HamzahS
I've tried this and it worked to generate the BSP, thanks a lot.
JingyangTeh_Altera
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome to reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
