Non CFI memory & SOPC builder
Hi to all,
I'd just finished to test my AM29LV400BB interface to the Avalon bus and now I'm trying to use it in SOPC builder.
I'd like to see the instance of the interface inside the flash memory devices (in SOPC builder), but I don't know where
to put the created module .
Does anyone knows how to proceed?
Is it possible use the flash programmer, inside the NIOS II IDE, with non CFI flash memories?
Thank you for the help.
You can add a "custom" Flash by "add Flash " under memory components in SOPC buider.
However, you should modify the parameters,such as time_hold, time_wait... according the AM29LV400BB dattasheet.
