PCI 3.3V IO
I was wondering if anyone has connected an FPGA and a PCI/Mini-pci Card with the IO standard set as 3.3V LVTTL instead of 3.3 PCI? PCI is still a 3.3V standard, but I'm not sure if the drivers are physically different in hte FPGA?
Thanks ,J
--- Quote Start ---
originally posted by jdhar@Jun 12 2006, 08:46 AM
i was wondering if anyone has connected an fpga and a pci/mini-pci card with the io standard set as 3.3v lvttl instead of 3.3 pci? pci is still a 3.3v standard, but i'm not sure if the drivers are physically different in hte fpga?
thanks ,j
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16098)
--- quote end ---
--- Quote End ---
I did use 3.3 LVTTL for onboard PCI. Thought the drive chart is different. There is no problem at 33MHz.
on-board meaning you didn&#39;t use an expansion card.. the interface was contained on the board? How far away was the device?
--- Quote Start ---
originally posted by jdhar@Jun 13 2006, 01:38 AM
on-board meaning you didn&#39;t use an expansion card.. the interface was contained on the board? how far away was the device?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16133)
--- quote end ---
--- Quote End ---
About 2-4 inches from the fpga.
I think a single mini-pci socket should be OK.
But if you want to drive several PCI slots, you would better use PCI capable pins.
did you use external components within the pci lines - as resistors to limit current or external clamping-diodes?
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16149)
--- quote end ---
--- Quote End ---
I use minimum current strength for most pins, including onboard ddr sdram and others.
I didn&#39;t use series resisters or clamping diodes.
series resistors on a PCI bus would suck if you were 1 inch out http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
