PS/2 Keyboard with C
i am trying to make a PS/2 Keyboard work with my FPGA and C language.
I tried to capture sequences from the keyboard by using the following code :
while(1) { while(1) { if(*ps2Data!=1) { printf("%d", *ps2Data); printf("%d", *ps2Data); printf("%d", *ps2Data); printf("%d", *ps2Data); printf("\n"); break; } } usleep(500000); }
However the sequences that i had captured are not always the same for 1 key they can be the same for two different keys.
For instance, when i pressed the 0 from the keypad it gave this (from the console) :
0001
0001
0101
0001
0001
0001
0001
And when i pressed the letter "N" i had :
0001
0101
0001
0001
0001
0001
0001
I know that there is a sequence when the key is pushed and an other one when the key is released, but i don't think that this is my problem.
Actually i only need the 0-9 digits from the keypad which should be easier to implement (i guess).
How could i do to capture the right sequences from the keyboard by using C ?
Thank you for helping me :)
What ps2Data is? Is it a pointer to the rx register of your ps2 serial port?
Why do you read it 4 times?
And, what's the meaning of if(*ps2Data!=1) ?
Usually you need to test a "rx ready" bit on rx status register in order to know if new data word is available.
