12748 Discussions
PS/2 device driver problem in uClinux
Hi,all
Is there any body has used PS/2 Keyboard and Mouse interface on Nios uClinux.
I set the configuration of uClinux kernel according to the website
www.alterawiki.com/wiki/frame_buffer (http://www.alterawiki.com/wiki/frame_buffer
However when I boot kernel, the ps/2 device doesn't work.
(The experimental approach is "cat /dev/input/mouse")
If I use the HAL software provided by Altera in NIOS IDE, the PS/2 device can work.
Therefore I don't have any idea about that.
Could you give me some suggestions .
Thank you very much.
I need help very much.
Could you help me .
