Performance Counter
I want to measure a time count taken for a section of a code. But the output i'm getting is always zero. I'm viewing my output through IDE output console.
I have patched my code and the output i got.
Note: Using Quarus II 4.2 SP1
Can anyone help me in this regard.
Sanchu.C
# #########################CODE#####################
# include <stdio.h># include "altera_avalon_performance_counter.h"# include "system.h"
void* perfbase = 0x00100800; # define COMPUTE_FUNCTION_SECTION 1
void compute()
int counter,sum;
sum=0;
PERF_BEGIN (perfbase, COMPUTE_FUNCTION_SECTION);
for(counter=0;counter<100;counter++)
sum=sum+counter;
PERF_END (perfbase, COMPUTE_FUNCTION_SECTION);
printf("\n Sum = %d \n",sum);
int main()
printf("Hello from Nios II!\n");
PERF_RESET (perfbase);
PERF_START_MEASURING (perfbase);
compute();
PERF_STOP_MEASURING (perfbase);
unsigned int section_time = 1;
section_time = perf_get_section_time (perfbase,COMPUTE_FUNCTION_SECTION);
printf ("section_time: %d\n",section_time);
perf_print_formatted_report(perfbase, ALT_CPU_FREQ,1,"compute");
return 0;
# ##################OUTPUT VIEW THROUGH IDE CONSOLE#####################
Hello from Nios II!
Sum = 4950
section_time: 0
--Performance Counter Report--
Total Time: 0 seconds (0 clock-cycles)
| Section | % | Time (sec)| Time (clocks)|Occurrences|
|compute | NaN| 0.00000| 0| 0|
Found a workaround for this problem:
It seems to work fine if I take the Verilog project from Standard folder under \kits\nios2\examples\verilog\niosII_stratix_1s10\standard and add performance counter to it.
If I take Vhdl project from Standard folder under \kits\nios2\examples\vhdl\niosII_stratix_1s10\standard then, it is not working fine.
--- Quote Start ---
originally posted by sanchu@Mar 15 2005, 06:23 AM
found a workaround for this problem:
it seems to work fine if i take the verilog project from standard folder under \kits\nios2\examples\verilog\niosii_stratix_1s10\standard and add performance counter to it.
if i take vhdl project from standard folder under \kits\nios2\examples\vhdl\niosii_stratix_1s10\standard then, it is not working fine.
--- Quote End ---
I&#39;m having the same problem... does anyone got it running using VHDL?
Paolo
yes for me it seem to work in vhdl,
i&#39;m using the kit cyclone(EP1C20) from altera, with nios2.1 quartus 4.2 sp1.
