12747 Discussions
Permission denied (public key) when running ./update with git on Nios2 Linux
hi, I am using Centos 6.4 on 64 bits OS and I follow the instruction at http://www.alterawiki.com/wiki/install_nios_ii_linux, I got the following error when running [/home/hippo/nios2-linux]# ./update
update binutils..
Already up-to-date.
update gcc3..
Already up-to-date.
update linux-2.6..
Already up-to-date.
update toolchain-build..
Already up-to-date.
update toolchain-mmu..
Already up-to-date.
update uClibc..
Already up-to-date.
update elf2flt..
Already up-to-date.
update insight..
Already up-to-date.
update u-boot..
Already up-to-date.
update uClinux-dist..
Already up-to-date.
update boards..
Already up-to-date.
update openip..
Permission denied (publickey).
fatal: The remote end hung up unexpectedly
update tools..
Your configuration specifies to merge with the ref 'master'
from the remote, but no such ref was fetched.
May I know how can I get over this? Is it necessary for openip and tools to get update?
--- Quote Start ---
update binutils..
Already up-to-date.
update gcc3..
Already up-to-date.
update linux-2.6..
Already up-to-date.
Already up-to-date.
Already up-to-date.
update uClibc..
Already up-to-date.
update elf2flt..
Already up-to-date.
update insight..
Already up-to-date.
update u-boot..
Already up-to-date.
Already up-to-date.
update boards..
Already up-to-date.
update openip..
update tools..
--- Quote End ---
Hi, I manage to resolve the issue by running git clone manually. git clone git://sopc.et.ntust.edu.tw/git/boards.git
git clonegit://sopc.et.ntust.edu.tw/git/openip.git
git clonegit://sopc.et.ntust.edu.tw/git/tools.git
I manage to resolve it by manually running inn terminal window:
git clone git://sopc.et.ntust.edu.tw/git/openip.git
git clone git://sopc.et.ntust.edu.tw/git/tools.git
