12745 Discussions
Porting Preloader generation to U-Boot 2016 - FAT Support
Hello all,
I am porting the altera preloader generation to new U-boot and I would need little help.
I am successfully building spl from U-boot configured for my board via QTS Files.
Problem is the FAT Support in this SPL.
When I enable the CONFIG_SPL_FAT_SUPPORT.
the single SPL File size is increased to ~258 000 bytes. (original is ~55 000 bytes)
my question here:
Is is possible to make this size same as in Altera U-boot 2013 when generated U-boot and preloader via bsp-editor?
I notice that in altera U-boot there is also some lowlevel confing when using the CONFIG_SPL_FAT_SUPPORT.
/* relocated the stack to SDRAM which is much bigger */
relocate_stack_to_sdram();
under arch/arm/cpu/armv7/socfpga/lowlevel_init.S
is these something similar in u-boot 2016 to enable fat support for spl and reach the required size?
Thank you for any advice.
BR,
TO
