12748 Discussions
Preloader can't access to QSPI
Hi All,
I'm working on a custom board - assembled with Arria 5 that boot from QSPI.
When i power on my board I can see on the tera term the peloader printouts ,but after preloader finishe his work
and try to read out the uboot from QSPI to DDR - it face some difficulties.
below are the printouts ( with the errors ) from the UART0 termial :
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 532 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 488 KHz
CLOCK: QSPI clock 400000 KHz
RESET: WARM
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
SDRAM: Scrubbing 0x01000000 - 0x02000000
SDRAM: Scrubbing success with 22 ms
SDRAM: Scrubbing 0x00000000 - 0x01000000
SDRAM: Scrubbing 0x02000000 - 0x40000000
SDRAM: ECC Enabled
SF: Read data capture delay calibrated to 7 (0 - 15)
SF: Unsupported manufacturer ff
SPI probe failed.# ## ERROR# ## Please RESET the board# ##
Please advise,
Thanks Moran.
hi there is some investigation needed at your qspi flash part, as it failed to detect that. any pull up register or hard configuration you have acidentally missed out?
I'm pretty sure this is because the U-Boot port on which this preloader is based upon does not fully support this flash.
As seen in the datasheet, the bit EXTADD of the Bank Address Register is set to 0 by default, and this means that
the FAST_READ (0Bh) command used by U-Boot expects to be followed by a 3-byte address, but since the device is > 16 MB,
U-Boot automatically uses a 4-byte address! So the preloader copies garbage to the DDR, and then tries to run it, the watchdog is
triggered, and so on...
There is also a similar problem related to the Normal or Quad operation.
The changes are not too difficult to implement, but actually Altera pushed last week a commit that adds this support!
So, you can take a look at this commit, and see if it solves your problem:
https://github.com/altera-opensource/u-boot-socfpga/commit/5a47f31c98e6c70185f3423bc82f3414cb25ca2c
replace the spansion.c file with the spansion.c file present in above link
I too faced this problem.my problem solved after replacing the file
