12747 Discussions
Problem mixing C and C++ codes
Hi all,
I am justing using NIOS IDE for one day.
I can compile/link C sources in IDE. I can also compile C++ sources, but linker complained "undedfined main",
since I compile the source with the 'main' function in a C++ way (because the main function needs to access C++ programs.
Any suggestion how to mix C codes with C++ classes?
Kwok Wong
--- Quote Start ---
originally posted by kwokwong@Jul 27 2004, 04:30 AM
hi all,
i am justing using nios ide for one day.
i can compile/link c sources in ide. i can also compile c++ sources, but linker complained "undedfined main",
since i compile the source with the 'main' function in a c++ way (because the main function needs to access c++ programs.
any suggestion how to mix c codes with c++ classes?
regards,
kwok wong
--- Quote End ---
Problem solved: define C main function in C++ program
extern "C" {
int main() {
// C++ codes
FYI, you can also say:
extern "C" int main() {    // C++ codes }
Might be a little easier on the eyes.
