Problem running ModelSim
Hello, I have just install Ubuntu 14.04 64 bit in my computer and I have install Quartus 2. It works well but I canꞌt use ModelSim, I recieve an error that says:
Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. Check the NativeLink log file
And the content of this file is:
Info: Start Nativelink Simulation process
Info: NativeLink has detected Verilog design -- Verilog simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : cycloneii
Quartus root : /home/juan/altera/13.0sp1/quartus/linux/
Quartus sim root : /home/juan/altera/13.0sp1/quartus/eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : verilog
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation/modelsim
Info: Starting NativeLink simulation with ModelSim-Altera software
Sourced NativeLink script /home/juan/altera/13.0sp1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: issued_nl_message
Nativelink TCL script failed with errorInfo: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
while executing
"error "$emsg" "" "issued_nl_message""
invoked from within
"if [ catch {exec $vsim_cmd -version} version_str] {
set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..."
(procedure "launch_sim" line 89)
invoked from within
"launch_sim launch_args_hash"
("eval" body line 1)
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if [ info exists ::errorCode ] {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $savedInfo $savedCode
} else {
invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
set status 1
set sav..."
(procedure "run_sim" line 78)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
error "$result" $savedInfo $savedCode
} else {
er..."
(procedure "run_eda_simulation_tool" line 330)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
I'm new using Quartus in ubuntu so I'm a little lost, I would be grateful if you can help me. I've been looking for solutions on google and but I have not found a lot. I found something about removing the .altera folder but it doesn't work for me. Thank you.
It looks like you installed the non-free Modelsim Altera version (with mixed VHDL/Verilog capability). You probably want to install the free Altera Starter Edition (which doesn't support mixed VHDL/Verilog simulation) and doesn't need a license file
Thank you very much for your answer. I installed the free version but I have reinstalled it again and I get the same error, the project I used was only Verilog and I could simulate it in Windows. I tried to give all the permissions to the install folder of modelsim but the error is still the same. Thank you for your help!
--- Quote Start ---
--- Quote End ---
Hi
I have the same problem and same error on Ubuntu 14.04 64bit, Quartus 13.0 works well (subscription edition, with a network license), but not MultiSim-Altera, either Starter Edition or Normal Edition.
On my previous Ubuntu 12.04 32bit, everything worked perfectly.
hello, I'm facing the same problem and I would like a help
I use Linux Mint 17 - 64 bit, I've installed 32 bit libraries but ModelSim still does not work.
I am having similar problems trying to run ModelSim-Altera Starter version 14.1.0.186 on Windows 7. See attachments.
