12748 Discussions
Problem with a small network program
Dear everyone:
I'm learning uClinux network programming. After download the kernel and filesystem to the board successfully, Now I am trying to run a small server and client program, but after running the programs, there is no react at all!
I can't find where the problem is...Can anyone help me?Thanks.
The program is:
**************** server program:**********************
int main(int argc,char *argv[])
int listensock,connsock;
struct sockaddr_in serveraddr;
const char buff[] = "Hello! Welcome here!\r\n";
printf("enter!\n");
listensock = socket(AF_INET,SOCK_STREAM,0);
bzero(&serveraddr,sizeof(struct sockaddr_in));
serveraddr.sin_family = AF_INET;
serveraddr.sin_addr.s_addr = htonl(INADDR_ANY);
serveraddr.sin_port = htons(5000);
bind(listensock,(struct sockaddr_in *)&serveraddr,sizeof(serveraddr));
listen(listensock,1024);
connsock = accept(listensock,(struct sockaddr_in *)NULL, NULL);
send(connsock,buff,sizeof(buff), 0);
close(connsock);
close(listensock);
**************** client program:**********************
int sockfd;
char recvbuff[100]={0};
if(argc!=2){
printf("Usage: echo ip address");
exit(0);
sockfd = socket(AF_INET,SOCK_STREAM,0);
serveraddr.sin_family=AF_INET;
serveraddr.sin_port=htons(5000);
inet_pton(AF_INET,argv[1],&(serveraddr.sin_addr));
connect(sockfd,((struct sockaddr_in*)&serveraddr),sizeof(serveraddr));
recv(sockfd,recvbuff,sizeof(recvbuff),0);
printf("%s\n" , recvbuff);
close(sockfd);
some clue:
1,I am not sure whether my run parameter is right, I run the program as below(in the command line):
server program: main
client program: main ×××.×××.×.××(The server's IP address)
2, I am not sure whether the assigned port(serveraddr.sin_port = htons(5000); listensock,1024); ) is right.
3, I just run the program after download the kernel and filesystem into the board without any modification. Is the driver for the network is necessary? My uClinux edtion is Microtronix Nios II Linux Distribution V1.4, and my board is Cyclone II 2C35.
4, There are some errors in the program..
Maybe some of my question is stupid, this is my first step to learn uClinux programing and I'm so confused, wish you can help me, thanks again!
you should check the return values of each function.
try
without htonl just INADDR_ANY.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Is the driver for the network is necessary[/b]
--- Quote End ---
drivers are necessary
--- Quote Start ---
try
serveraddr.sin_addr.s_addr = htonl(inaddr_any);
without htonl just inaddr_any.
<div class='quotetop'>quote </div>
--- quote start ---
is the driver for the network is necessary
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20682)</div>
[/b]
--- Quote End ---
Helmchen,Thank you very much!!
