12748 Discussions
Problem with build jfss2 filesystem
I do uclinux porting on my own board, use the "uClinux-dist-20060803" released kernel, custom the kernel as follow:
Memory Technology Devices (MTD) -->
<*> Memory Technology Device (MTD) support
[*] MTD partitioning support
<*> Direct char device access to MTD devices
<*> Caching block device access to MTD devices
RAM/ROM/Flash chip drivers -->
<*> Support for Altera EPCS Device
Mapping drivers for chip access -->
<*> Maps for Altera EPCS Configuration Device
File systems -->
Miscellaneous filesystems -->
<*> Journalling Flash File System v2 (JFFS2) support
then try "make", but there are some errors:
make[3]: Leaving directory `/home/gaobing/uClinux-dist/user/games&#39;
[ ! -d "init" ] || ( touch init/.sgbuilt_user && make -j1 -C init ) || exit $?
make[3]: Entering directory `/home/gaobing/uClinux-dist/user/init&#39;
make[3]: Nothing to be done for `all&#39;.
make[3]: Leaving directory `/home/gaobing/uClinux-dist/user/init&#39;
[ ! -d "mtd-utils" ] || ( touch mtd-utils/.sgbuilt_user && make -j1 -C mtd-utils ) || exit $?
make[3]: Entering directory `/home/gaobing/uClinux-dist/user/mtd-utils&#39;
gcc -I/usr/include -I. -Dprintk=printf -DKERN_NOTICE= -DKERN_WARNING= -c -o build/compr_zlib.o compr_zlib.c
compr_zlib.c:38:18: error: zlib.h: &#27809;&#26377;&#37027;&#20010;&#25991;&#20214;&#25110;&#30446;&#24405;
compr_zlib.c: &#22312;&#20989;&#25968; ‘zlib_compress’ &#20013;&#65306;
compr_zlib.c:81: &#38169;&#35823;&#65306;‘z_stream’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:81: &#38169;&#35823;&#65306;(&#21363;&#20351;&#22312;&#19968;&#20010;&#20989;&#25968;&#20869;&#22810;&#27425;&#20986;&#29616;&#65292;&#27599;&#20010;&#26410;&#22768;&#26126;&#30340;&#26631;&#35782;&#31526;&#22312;&#20854;
compr_zlib.c:81: &#38169;&#35823;&#65306;&#25152;&#22312;&#30340;&#20989;&#25968;&#20869;&#21482;&#25253;&#21578;&#19968;&#27425;&#12290;)
compr_zlib.c:81: &#38169;&#35823;&#65306;syntax error before ‘strm’
compr_zlib.c:91: &#38169;&#35823;&#65306;‘strm’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:95: &#38169;&#35823;&#65306;‘Z_OK’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:110: &#38169;&#35823;&#65306;‘Z_PARTIAL_FLUSH’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:121: &#38169;&#35823;&#65306;‘Z_FINISH’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:122: &#38169;&#35823;&#65306;‘Z_STREAM_END’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c: &#22312;&#20989;&#25968; ‘zlib_decompress’ &#20013;&#65306;
compr_zlib.c:143: &#38169;&#35823;&#65306;‘z_stream’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:143: &#38169;&#35823;&#65306;syntax error before ‘strm’
compr_zlib.c:150: &#38169;&#35823;&#65306;‘strm’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:154: &#38169;&#35823;&#65306;‘Z_OK’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:166: &#38169;&#35823;&#65306;‘Z_FINISH’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
compr_zlib.c:168: &#38169;&#35823;&#65306;‘Z_STREAM_END’ &#26410;&#22768;&#26126; (&#22312;&#27492;&#20989;&#25968;&#20869;&#31532;&#19968;&#27425;&#20351;&#29992;)
make[3]: *** [build/compr_zlib.o] &#38169;&#35823; 1
make[3]: Leaving directory `/home/gaobing/uClinux-dist/user/mtd-utils&#39;
make[2]: *** [mtd-utils] &#38169;&#35823; 2
make[2]: Leaving directory `/home/gaobing/uClinux-dist/user&#39;
make[1]: *** [all] &#38169;&#35823; 2
make[1]: Leaving directory `/home/gaobing/uClinux-dist/user&#39;
make: *** [subdirs] &#38169;&#35823; 1
It seems the library-include problem, in "make menuconfig", I choose "none" library include, did it wrong? What should I do to exclude the errers?
Need help,ths!
giantice
02th Feb 2007
You will need zlib to build user/mtd-utils/build/mkfs.jffs2.
Make sure you have zlib install in your Linux PC.
--- Quote Start ---
originally posted by hippo@Feb 2 2007, 12:05 PM
you will need zlib to build user/mtd-utils/build/mkfs.jffs2.
make sure you have zlib install in your linux pc.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21139)
--- quote end ---
--- Quote End ---
hi hippo,
thanks for your help, now I can successfully make the kernel, but when I download and mount the jffs2, there is problem:
/> mount -t jffs2 /dev/mtdblock0 /mnt
jffs2: Too few erase blocks (0)
mount: Mounting /dev/mtdblock0 on /mnt failed: Invalid argument
I see the post before as follow:
You need to learn flash programmer before using mtd.
First, resize your cfi flash to 4M base addr 0 ,in sopc builder, and regenerate sof.
Then enable epcs mtd and cfi mtd,
in drivers/mtd/maps/
edit epcs_map.c
CODE
static struct mtd_partition epcs_partitions[] =
.name = "sof_kernel",
.size = 0x200000,
.offset = 0x000000,
static const char *part_probes[] __initdata = {NULL};
edit altera.c
CODE
static struct mtd_partition alteramap_partitions[] = {
.name = "romfs/jffs2",
.size = 0x400000,
.offset = 0x000000,
Rebuild kernel image from the start "make clean", "make linux_hwselect...."....
Follow the wiki,
http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operating...flashprogrammer
To program sof and zImage to your EPCS.
And erase cfi flash.
Did it the problem of epcs_map.c and edit altera.c. I use the EPCS4, which is as large as 512Kbytes.
Should edit the files of epcs_map.c and edit altera.c? How to do it.
Waiting your reply, ths!
Ths again for the bison problem I post before, I download the bison package installed ,then make success, there is no ftp build problems.
giantice
02th Feb 2007
[ ] Detect non-CFI AMD/JEDEC-compatible flash chips
Don&#39;t detect non-CFI.
And please note, the epcs4 is used to store fpga config, plus kernel image.
So there won&#39;t be much space left for jffs2.
