uClinux makefile
Does anyone know how to create a makefile for a uClinux project consisting several .c and .h files. I am having trouble linking any function to "main"which are not in the same .c file(but in the same application project folder).
For example I am getting an error:
mpeg2enc.bin(.text+0xf0): In function `main':
/cygdrive/c/Anika/uc/strx1/sw/mpg/mpeg2enc.c:70: undefined reference to `putseq'
putseq is another .c file which is in the same application project but not in the same file(mpeg2enc.c-> main).
Right now my makefile looks like this:
**********************************# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 1
PROJ_NAME = mpg
INSTALL_DIR = ./build
PROGS := mpeg2enc.exe
OBJ = mpeg2enc.o conform.o putseq.o putpic.o puthdr.o putmpg.o putvlc.o putbits.o motion.o predict.o readpic.o writepic.o transfrm.o fdctref.o idct.o quantize.o ratectl.o stats.o
LIBCDIR := C:\Altera5\kits\bin\eclipse\plugins\com.microtronix.nios2linux.uClibc_1.4.0
UTILSDIR := C:\Altera5\kits\bin\eclipse\plugins\com.microtronix.nios2linux.application_1.4.0
CFLAGS +=
# # You should not need to modify anything beyond this point#
TOPDIR = ./
include Rules.mak
ifeq '$(DEBUG)' '1'
PROGS += $(PROGS:.exe=.gdb)
endif
all: $(PROGS)
clean:
rm -f *.o *% core mpeg2encode
mpeg2enc.exe: mpeg2encode
coff2exe mpeg2enc
mpeg2encode: $(OBJ)
$(CFLAGS) -o mpeg2encode $(OBJ) -lm
conform.o : conform.c config.h global.h mpeg2enc.h
fdctref.o : fdctref.c config.h
idct.o : idct.c config.h
motion.o : motion.c config.h global.h mpeg2enc.h
mpeg2enc.o : mpeg2enc.c config.h global.h mpeg2enc.h
predict.o : predict.c config.h global.h mpeg2enc.h
putbits.o : putbits.c config.h
puthdr.o : puthdr.c config.h global.h mpeg2enc.h
putmpg.o : putmpg.c config.h global.h mpeg2enc.h
putpic.o : putpic.c config.h global.h mpeg2enc.h
putseq.o : putseq.c config.h global.h mpeg2enc.h
putvlc.o : putvlc.c config.h global.h mpeg2enc.h vlc.h
quantize.o : quantize.c config.h global.h mpeg2enc.h
ratectl.o : ratectl.c config.h global.h mpeg2enc.h
readpic.o : readpic.c config.h global.h mpeg2enc.h
stats.o : stats.c config.h global.h mpeg2enc.h
transfrm.o : transfrm.c config.h global.h mpeg2enc.h
writepic.o : writepic.c config.h global.h mpeg2enc.h
I'll really appreciate if someone could help me in this regard.
Anika http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
You&#39;d better move to Linux PC and follow the nios wiki.
http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux
It will be easier to port apps.
--- Quote Start ---
originally posted by hippo@Feb 4 2007, 08:44 PM
you&#39;d better move to linux pc and follow the nios wiki.
it will be easier to port apps.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21228)
--- quote end ---
--- Quote End ---
Thanks for the suggestion. Unfortunately, at this moment it is not possible to have uClinux on linux PC&#39;s at Ryerson. My code is working perfect just on Nios II IDE(without uClinux) though, because I think Nios II IDE uses it&#39;s own makefile, where as for uClinux I need to create a makefile.
So any other suggestion how to create the makefile for my app project(consists of several .c and .h files) in uClinux?
