12746 Discussions
Problem with framebuffer from nioswiki
i try to build a custum linux kernel with framebuffer from nioswiki. I build a nios 2 system with sopc builder with nios2,jtag uart,timer,sdram and vga controller for the terasic de1 board. The vga controller works in nios2 ide with the sample c code from nioswiki. The default uclinux kernel works also with this system.
When i try to enable the framebuffer in kernel config i get this error :
drivers/built-in.o(.text+0xfa0): In function `fb_mmap':
drivers/video/fbmem.c:1219: undefined reference to `io_remap_pfn_range'
make[1]: *** [vmlinux] Fehler 1
make: *** [linux] Fehler 1
i solved the problem http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
i had to define io_remap_pfn_range in /include/asm-nios2nommu/pgtable.h
#define io_remap_pfn_range    remap_pfn_range
updated the patches for pgtable.h .
