i use mk_taget_board cmd to creat my custome board ,but it appears this error.
software verson 5.1 enter the cmd in NIOS II SDK SHELL: [SOPC Builder]$ mk_target_board --name=Hard_Board_2c5 --family=CycloneII --clock=22.1184 --index=1 --buffer_size=2048 --class=name=Hard_Board_CycloneII_2c5 --epcs=U6 output the results in screen: Make Target Board version 1.01 Switch summary: Board name: "Hard_Board_2c5" Board class: Hard_Board_CycloneII_2c5 Device family: "Cyclone II" Clock frequency: 22118400hz Payload buffer size: 2048 bytes EPCS flash enabled with reference designator:U6 ERROR: c:/altera/kits/nios2_51/bin/create-board.pl 1279 CALLED (main) c:/altera/kits/nios2_51/bin/create-board.pl 99 CALLED (cb_setup_directories) c:/altera/kits/nios2_51/bin/create-board.pl 511 CALLED(europa_utils::find_component_dir) /cygdrive/c/altera/quartus51/sopc_builder/bin/europa/europa_utils.pm 2030 CALLED (europa_utils::ensure_class_ptfs)WHERE ‘get_class_ptg and ensure_class_ptfs must be called with g{system_directory}’OCCURRED on /cygdrive/c/altera/quartus51/sopc_builder/bin/europa/europa_utils.pm 1923Link Copied
