Problem with getty
I try to add a login to uClinux-dist-20060803 patch V32.
I've added to busybox adduser/ addgroup / deluser / delgroup / login / su / passwd / getty / shadowpw support.
It works pretty fine when I connect to my board with a telnet client, but on the ttyS0 console it looks good but the keyboard is disabled ... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
I&#39;ve added to /etc/inittab:
ttyS0:vt100:/sbin/getty -L 9600 ttyS0
or
ttyS0:vt100:/sbin/getty 9600 ttyS0
or with others speed ... the same.
I&#39;ve tried with tinylogin : same behavior, but with an IOCTL error message.
If someone could help me ... thanks !
LeFred.
You should disable the console shell in the simple init.
Core Applications-->
[*] init
[ ] enable console shell <==
The getty in busybox might take more memory. You should try agetty, which is standalone.
[*] agetty
It works fine now ! Thanks Hippo http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
About the used RAM memory:
Busybox/getty -> 514 k
standalone agetty -> 130 k !!
Once again ... Thanks Hippo http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
