Hi all,
I've loaded template in Nios EDS 6.0 with web.server template using NicheStack TCP/IP and Micro/C OS-II and I've run on Nios development board but I haven't found anywhere a tutorial relating this example. Can anyone help me to have a copy about this .pdf tutorial ????? Thanks a lot in advanceLink Copied
You're using an older version...update to 6.1 and you'll see a NicheStack web server.
Cheers, - slacker
