12748 Discussions
WebServer NicheStack example
Hi all,
I've loaded template in Nios EDS 6.0 with web.server template using NicheStack TCP/IP and Micro/C OS-II and I've run on Nios development board but I haven't found anywhere a tutorial relating this example.
Can anyone help me to have a copy about this .pdf tutorial ?????
Thanks a lot in advance
You're using an older version...update to 6.1 and you'll see a NicheStack web server.
Cheers,
- slacker
