Problem with jssf2
Could someone help me to start working with jffs2 file system?.
I use following code: # include <cyg/hal/io.h># include <cyg/kernel/kapi.h># include <cyg/io/io.h># include <cyg/fileio/fileio.h># include "stdio.h"
void cyg_user_start(void)
int err;
# ifdef CYGPKG_IO_FILEIO
err=mount ("/dev/flash", "/", "jffs2");
printf("%d\n",err);
if(err == 0)
printf("success");
chdir ("/");
# endif
but when I start my app i receive:
-1
so there is some error and I dont know what kind of error and how to fix it.
My flash memory is filled with 0xFF patterns.
Hi Mell,
Have you configured ecos to use your flash memory, and set aside a block of memory for JFFS2? You need to set the "Instantiate in I/O block device API" property in the flash drivers section.
I had a problem with JFFS2 on my Altera Cyclone II 2C35 based Dev Board because the flash memory is connected as 8-bit and the ecos driver expects it to be in 16-bit mode. I can send you code to fix this if you need it.
I found JFFS2 quite tricky to get started with, but once it starts working it&#39;s great!
Mike
Hi Mike,
I&#39;ve configured eCos Library using NiosII config tool. I imported all required packages: JFFS2 Filesystem, Generic FLASH memory support, CRC support, Linux compatibility. I configured base of flash device block to 0x0000 and length of 16Mbytes(as we have in our system).
I use the same evaluation board as you.
Hi Mell,
I solved my problem with JFFS2 by following the advice in this post:
previous post (http://forum.niosforum.com/forum/lofiversion/index.php/t1841.html
If you need help implementing this solution then let me know.
Mike
Hello mike,
I&#39;ve read contens of link you sent, but I wasn&#39;t able to find any of files mentioned in neither in project path nor in installation of eCos.
Hi Mell,
On my system the two files you need to edit are in these locations:
C:\altera\kits\nios2_60\components\ecos\ecos-current\packages\devs\flash\sopc\altera_avalon_am29lv065d_flash\current\src\altera_avalon_am29lv065d_flash.c
C:\altera\kits\nios2_60\components\ecos\ecos-current\packages\devs\flash\amd\am29xxxxx\current\include\flash_am29xxxxx_parts.inl
The file called altera_avalon_am29lv065d_flash.c contains a definition of the flash geometry that is being used. Near the top of the file you will find some code like this:
   # define CYGNUM_FLASH_INTERLEAVE  (1)    # define CYGNUM_FLASH_SERIES         (1)    # define CYGNUM_FLASH_WIDTH          (8)    # define CYGNUM_FLASH_BASE       altera_avalon_am29lv065d_base
You need to add a line to this to specify that the flash is being used in 8-bit mode, like so:
#define CYGNUM_FLASH_INTERLEAVE (1)# define CYGNUM_FLASH_SERIES     (1)# define CYGNUM_FLASH_WIDTH      (8)# define CYGNUM_FLASH_16AS8    (1)# define CYGNUM_FLASH_BASE    altera_avalon_am29lv065d_base
The second file called flash_am29xxxxx_parts.inl contains the settings required to drive the flash. It consists of a long list of flash settings. The defines in the previous file cause parts of the second file to be enabled. We need to add a new section to flash_am29xxxxx_parts.inl to describe the flash being used in 8-bit mode.
Search for this code in the file (Somewhere around line 560):
#else // 16 bit devices # ifdef CYGHWR_DEVS_FLASH_AMD_AM29LV128    {   // AM29LV128        device_id  : FLASHWORD(0x227e),          block_size : 0x10000 * CYGNUM_FLASH_INTERLEAVE,        block_count: 256,        device_size: 0x1000000 * CYGNUM_FLASH_INTERLEAVE,        base_mask  : ~(0x1000000 * CYGNUM_FLASH_INTERLEAVE - 1),        bootblock  : false,        banked     : false,        bufsiz     : 16    },# endif
This is the existing code for 16-bit access to the flash. You need to add an 8-bit section before the# else statement like so:
#ifdef CYGHWR_DEVS_FLASH_AMD_AM29LV128     { // AM29LV128  long_device_id: true,  device_id : FLASHWORD(0x7e),  device_id2 : FLASHWORD(0x12),  device_id3 : FLASHWORD(0x00),  block_size : 0x10000 * CYGNUM_FLASH_INTERLEAVE,  block_count: 256,  device_size: 0x1000000 * CYGNUM_FLASH_INTERLEAVE,  base_mask : ~(0x1000000 * CYGNUM_FLASH_INTERLEAVE - 1),  bootblock : false,  banked : false,  bufsiz : 16     },# endif # else // 16 bit devices # ifdef CYGHWR_DEVS_FLASH_AMD_AM29LV128    {   // AM29LV128        device_id  : FLASHWORD(0x227e),          block_size : 0x10000 * CYGNUM_FLASH_INTERLEAVE,        block_count: 256,        device_size: 0x1000000 * CYGNUM_FLASH_INTERLEAVE,        base_mask  : ~(0x1000000 * CYGNUM_FLASH_INTERLEAVE - 1),        bootblock  : false,        banked     : false,        bufsiz     : 16    },# endif
The tabs have been messed up by pasting into this message. If I knew how to send attachments through this forum then I would send these files to you. You could send me a "personal message" through the forum with your email address and I could then send the files directly to you.
Mike
My problem now seems to be solved. It was caused by bad description of board and missing device drivers for my flash.
That&#39;s great! Glad I could help.
Mike
