12748 Discussions
Problems mounting CompactFlash
I'm Using the Quartus 5.1, Nios 5.1, and eCos for 5.1.
I'm using the project with the CompactFlash support from the Forum.
I have build the Libraries, and compiled the the fileio1.c just fine. I modified the device name to /dev/cfa/0 as indicated in the Readme file. But when I try to run the program from the SDK shell or from the IDE, I always get the same error:
<FAIL> mount() returned -1 unknown error
<FAIL> chdir() returned -1 No such entity
I have also tried /dev/cfa/1, /dev/cfb/0, and /dev/cfb/1 with the same result
Make sure you are not using the LCD and CF on the same I/O pins.
--- Quote Start ---
originally posted by mumford@Oct 23 2006, 12:04 AM
make sure you are not using the lcd and cf on the same i/o pins.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18843)
--- quote end ---
--- Quote End ---
Also make sure you are using a Quartus project that enables the compact
flash. I had similar problems until I realized that my project did not set up
the compact flash component.
