12748 Discussions
printf's problem under uclinux
I wrote a socket program like below:# include <sys/types.h># include <sys/socket.h># include <sys/ioctl.h># include <sys/time.h># include <netinet/in.h># include <arpa/inet.h># include <netdb.h># include <stdio.h># include <signal.h># include <unistd.h>
int main()
int sd;
struct sockaddr_in sin;
char buf[1024];
int n;
if((sd=socket(AF_INET,SOCK_STREAM,0))==-1)
perror("can&#39;t creat socket!");
exit(1);
printf("creat socket!");
sin.sin_family=AF_INET;
sin.sin_addr.s_addr=htonl("192.168.135.99");
sin.sin_port=htons(1989);
if(connect(sd,(void*)&sin,sizeof(sin))==-1)
perror("can&#39;t connect!");
exit(1);
printf("connect socket!");
printf("input a message:\n");
fgets(buf,sizeof(buf),stdin);
if((n=send(sd,buf,sizeof(buf),0))==-1)
perror("can&#39;t send message!");
exit(1);
if((n=recv(sd,buf,sizeof(buf),0))==-1)
perror("receive error!");
exit(1);
printf("response from server:%s",buf);
close(sd);
when I run it under uclinux, the printf can&#39;t work because I can&#39;t get any message
in the sdk.
Can anyone help me ?
Thank you.
You can NOT use SDK/HAL API for uClinux.
Search this forum, and you may find some socket prog examples.
by the way
cannot work.
replace it:
sin.sin_addr.s_addr=inet_addr("192.168.135.99");
there are tons of examples in the internet....
thank you for all your help.
now the printf can run,but my server program and client program can&#39;t run normally.it says:can&#39;t connect!:connection refused!
my server.c and client.c are like below.
client.c:# include <sys/types.h># include <sys/socket.h># include <sys/ioctl.h># include <sys/time.h># include <netinet/in.h># include <arpa/inet.h># include <netdb.h># include <stdio.h># include <signal.h># include <unistd.h>
int main()
int sd;
char buf[1024];
int n;
exit(1);
sin.sin_addr.s_addr=inet_addr("192.168.135.99");//the server ip
sin.sin_port=htons(7777);
exit(1);
exit(1);
exit(1);
close(sd);
the server.c :# include <sys/types.h># include <sys/socket.h># include <sys/ioctl.h># include <sys/time.h># include <netinet/in.h># include <arpa/inet.h># include <netdb.h># include <stdio.h># include <signal.h># include <unistd.h>
# define max 1024
int main ()
int sd,cd;
int slen,clen;
struct sockaddr_in sin,cin;
char buf[max];
int i,n;
exit(1);
sin.sin_addr.s_addr=inet_addr(INADDR_ANY);
slen=sizeof(sin);
clen=sizeof(cin);
if(bind(sd,(struct sockaddr*)&sin,slen)==-1)
perror("bind error!");
exit(1);
if(listen(sd,20)==-1)
perror("listen error!");
exit(1);
printf("waiting for connections from clients!\n");
if((cd=accept(sd,(struct sockaddr*)&cin,&clen))==-1)
perror("accept error!");
exit(1);
if((n=recv(cd,buf,sizeof(buf),0))<0)
exit(1);
printf("received from the client:IP:%d port:%d %s\n",
ntohl(cin.sin_addr.s_addr),ntohs(cin.sin_port),buf);
for(i=0;i<=n;i++) buf=toupper(buf);
if((n=send(cd,buf,n,0))<0)
perror("send error!");
exit(1);
close(cd);
Is there any wrong?
thank you.
in replace in your server code
with
sin.sin_addr.s_addr=INADDR_ANY;
