Q message allocation
This is just a general question about messaging and queues.
How are you guys allocating Q messages? For instance, each message I send is a pointer to a struct. My struct contains an ENUM value and a pointer. In all my message structure is 8 bytes.
When I post to a Q, I send a pointer to one of these message structures.
Should I be using the memory management functions every time and doing dynamic memory allocation of one of these message structures? I don't really know how else to do it without allocating a bunch of global msg structs at compile time.
Any insight to this would be appreciated.
I prefer to use ring buffers. i do a calculation what ring buffer size is needed and add some safety margin.
Personally i am not a friend of dynamic memory allocation and freeing in embedded systems.
Unless you have a serious memory shortage i see nothing wrong with allocating big chunks of memory at compile time. At least so see then very early were potential bottlenecks lie.
Its also easier to test.
