12748 Discussions
Simple Socket Server and DE2_NET
Hi all,
I'm trying to understand how to work with ethernet... I've found 2 possible startin point, but i've problems with both of them
Q1)
someone can tell me where i can find a list of the component of SOPC builder for SSS template?
Or if there's a tutorial for my board altera DE2(cyclone II 2C35)
Q2) i've tried to run DE2_NET demo, but it's too old, and even if i've upgraded
to newest hardware, i still have errors in SOPC(you can see them in "errors.jpg")
Someone can help?
No one has some suggestions?
Even other ideas on what I can use to start with ethernet?
Hi Phil82,
for the Simple Socket Server Sample you don't need that much.
CPU, RAM, Timer, FLASH, a UART (i.e. the JTAG UART) and a MAC. The only thing you have to eventually edit are the names of the module names in the SSS Code. If your flash component in SOPC Builder is not named "ext_flash" you have to change it in sopc builder to this name, or in the source code to your name in sopc builder.
I don't know the specification of your DE2 Board, but is it right that you have two CPUs?
The error looks like that there is a conflict with the addresses. Have you tried to "Auto-Assign Base Addresses"?
