12748 Discussions
Question about uclinux on nios
I'm studying nios and uclinux and met a question when I read source code in linux-2.0.x on cvs.uclinux.org.
The question is:
At the entry of sys_fork and sys_vfork, why use SAVE_LAST_WINDOW and STORE_WINDOW to store essential reg info? but at the entry of sys_clone, use FLUSH_WINDOWS. From the codes of the same part of sparcnommu, it use the method similar to FLUSH_WINDOWS to store essential reg info at the entry of sys_fork, sys_vfork, sys_clone.
So why use SAVE_LAST_WINDOW and STORE_WINDOW but not FLUSH_WINDOWS in nios porting? and what it means the spare_reg_window variable in thread_struct struct in asm-niosnommu/processor.h?
thanks!
You should not work on Nios anymore. You should move to Nios II.
Follow the wiki,
http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux)
--- Quote Start ---
originally posted by hippo@Jan 3 2007, 08:35 PM
you should not work on nios anymore. you should move to nios ii.
follow the wiki,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20339)
--- quote end ---
--- Quote End ---
thanks for your reply, hippo.
But I still want to understand those macro&#39;s usage http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
