device driver module
I am currently writing a kernel device driver module. Added and modified Makefiles and Kconfig, and it seems to work.
As I am actively developing and debugging code, it takes a long time everytime I change a line in this driver, and had to recompile the entire kernel.
Does anyone how to just remake the module without having to make the entire kernel ?
you can insert module with
insmod mymodule
and remove a module with
rmmod mymodule
when your linux is running. However it is necessary to enable module loading and unloading feature, when you configure your kernel
Have a nice day
Thanks, but what i really want to know is there a quicker way to generate the module rather than going through
make
make linux image;
E.g. if I change a line of code when debugging the driver, it would take me 2 minutes to find out if there there is an error in the driver code.
How do I make building the kernel driver module as a separate project ?
please have a look at
1) http://forum.niosforum.com/forum/index.php?showtopic=2411&hl= 2) http://forum.niosforum.com/forum/index.php?showtopic=2522&hl=
it works with the microtronix port.
but i didn't test it with nioswiki buildroot ( i assume you are using this).
Thanks hippo. I will give it a try.
wiki page updated again. to build module alone inside the kernel tree.
