12745 Discussions
Question on modifying the JAM Staple byte code player
I am trying to call peek/poke type of function written in C++ from Altera provided JAM Staple Byte Code player C code. In doing so I need to start including stdafx.h and other header files in the C code. But Visual studio errors out in doing so. I need to call these customized get/put functions written in C++ from C code. I am not sure what is the best way to handle this.
Your suggestions will be very helpful to me.
Not much info to go on, but if you don't already know, try looking up info on:
extern "C" { // code and/or header info here }
I have patched the jamstub.c file to use InpOut32.DLL.
Posted source & binaries on alterawiki.com
