12744 Discussions
RUN configuration about Byte stream device
wuxin
hello
  I want run program on 2 NIOS core。one NIOS core for application, and the other one for stack。
  when I open target configuration, there display two NIOS core and one byte-stream-device。 while according to the standard instruction guide,there should display two byte-stream-device(instance id 0 and instance id 1)。
  how can I find the second byte-stream-device? and what the function of the byte-stream-device?
JingyangTeh_Altera
Hi
The view that you are getting looks ok.
You should be selecting the processor instance instead of the Byte stream device.
The byte stream device is the usb blaster that you are using.
To flash the nios you would need to select the instance you would like to flash.
In your case there are instance 0 and instance 1.
Jingyang, Teh
JingyangTeh_Altera
Hi
Do you have any follow up question for this?
Jingyang, Teh
wuxin
thanks JingyangTeh. no quesiont any more.
JingyangTeh_Altera
Hi
I’m glad that your question has been addressed, I will now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
