12744 Discussions
SoC EDS Command Shell not running
JesusAngelG
Good afternoon, I am trying to use the SoC EDS Command Shell software to use the HPS on the DE1-SoC Rev G card. However, when I try to run it (normally or as administrator) the program does not run. How can I get the program to run properly?
Note: I have already tried to resolve the problem by following the instructions in the following document, however the problem persists:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_soc_eds.pdf#page=12
Thank you
Jeet14
Please follow the steps for installation and the step to open the SoCEDS embedded command shell.
https://www.rocketboards.org/foswiki/Documentation/SoCEDS
Tiwari
Jeet14
Let me know if you have any question on this.
Tiwari
JesusAngelG
Thank you very much for your attention and your response, which was very helpful. The problem has already been solved.
Jeet14
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
