Recompiling mmu toolchain
NOTE: I actually posted this in the IP and Dev Kit forum first but I eventually realized this toolchain is not the standard FPGA dev tool and I might get better visibility over here.
I'm using nios2-linux-20100621.tar with my 3C120 Dev Board (ghrd.sof) and my statically compiled application is getting a segfault when I use the atan2 function in the math library from the binary mm toolchain.
root:/tmp> ./atan2_test 0 1
y = 0.000000
x = 1.000000
fabs (0.000000 / 1.000000) = 0.000000
atan (0.000000 / 1.000000) = 0.000000
atan (fabs(0.000000 / 1.000000)) = 0.000000
atan2 (0.000000, 1.000000) = 0.000000
root:/tmp> ./atan2_test 1 -1
y = 1.000000
x = -1.000000
fabs (1.000000 / -1.000000) = 1.000000
atan (1.000000 / -1.000000) = -0.785398
atan (fabs(1.000000 / -1.000000)) = 0.785398
SEGV
Although the atan function seems to work, it appears that the atan2 function dies trying to call it.
To get past this, I've been reading all the threads about the mmu toolchain and it does not appear that anyone has ever successfully recompiled the mmu toolchain. Is this the case? I've seen a few notes that a common toolchain is coming but they were old (2009?). Can anyone help point me to a resource on how to rebuild the mmu toolchain?
See here:
http://alterawiki.com/wiki/build_the_gcc4_toolchain
I have the build working. There is actually a slightly newer version I found from CodeSourcery that I've been using. At some point I started working on importing it into git, but that got put off.
I don't seem to be able to find the niosftp site. Is there a mirror?
Hi Gregdowd,
the niosftp.com server does not exist anymore. I don't know if it will become available again.
But you can use the following ftp site for downloading toolchain and linux distribution:
Toolchain:
ftp://sopc.et.ntust.edu.tw/pub/gnutools/ (ftp://sopc.et.ntust.edu.tw/pub/
Linux:
ftp://sopc.et.ntust.edu.tw/pub/linux/
Urmel
