12748 Discussions
Reconfiguration of the board
Hello
I'm making a project on the Nios 1c20 board running uClinux and I'm trying to make a program for reconfigure the board via the ethernet connection. My problem is that I don't know how to acces to the flash memory of the board or if this is possible. Can anyone help me?
With regards,
xanfia
You can use MTD device on CFI flash or EPCS, depending on where your board get config data.
Convert the config data , then copy the binary configuration file to the MTD.
I will update the wiki in more details.
http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/flashprogrammer)
Thank you Hippo for your reply, it was exactly what I was searching.
--- Quote Start ---
originally posted by xanfia@Apr 4 2007, 05:21 PM
thank you hippo for your reply, it was exactly what i was searching.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22791)
--- quote end ---
--- Quote End ---
Please check the update under the subheader,
Convert .flash file to binary, remote update
