- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
My application is similar to the examples found with the Nios II IDE (simple_socket_server...). It is based on microC/OS-II and NicheStack. Bassically, I send/receive UDP packets to/from the Cyclone FPGA. In the network_utilitities.c file, I have the get_ip_addr routine that is called by InterNiche. When I run the application, I can see on the IDE console the IP address obtained with DHCP: Acquired IP address via DHCP client for interface: et1 IP address : 192.168.68.197 Is there a function that I can call in my application to get this IP address value? Thanks MartinLink copiado
2 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
It's available in one of two existing data structures:
nets netstatic Just try debugging your code, and you'll see what I mean. Here's a quick sample, using netstatic:/* Declare local ipaddr variable. */
ip_addr* ipaddr;
/* Assign ipaddr to the network interface's IP Address.
* NOTE: This code assumes that only a single network
* interface exists
ipaddr = &netstatic.n_ipaddr;
including the header, ipport.h, then gets you the ip4_addr[1-4] convenience macros... For example, the following should print your attained IP address: printf("\nIP Address\n%d.%d.%d.%d\n",
ip4_addr1(*ipaddr),
ip4_addr2(*ipaddr),
ip4_addr3(*ipaddr),
ip4_addr4(*ipaddr));
NOTE: You could also do the same thing with nets, I believe, though I've not tried that. Cheers, - slacker
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Slacker,
Firstly, thanks for the fast answer. I had success with the nets data structure. # ############################# ip_addr my_ip_addr; my_ip_addr = nets[0]->n_ipaddr;# ############################# For the netstatic data structure, it was undeclared. Regards Martin
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
