12748 Discussions
Retrieve the IP address (DHCP)
My application is similar to the examples found with the Nios II IDE (simple_socket_server...). It is based on microC/OS-II and NicheStack. Bassically, I send/receive UDP packets to/from the Cyclone FPGA.
In the network_utilitities.c file, I have the get_ip_addr routine that is called by InterNiche. When I run the application, I can see on the IDE console the IP address obtained with DHCP:
Acquired IP address via DHCP client for interface: et1
IP address : 192.168.68.197
Is there a function that I can call in my application to get this IP address value?
Martin
It's available in one of two existing data structures:
nets
netstatic
Just try debugging your code, and you'll see what I mean. Here's a quick sample, using netstatic:
/* Declare local ipaddr variable. */ ip_addr* ipaddr; /* Assign ipaddr to the network interface's IP Address. * NOTE:  This code assumes that only a single network * interface exists */ ipaddr = &netstatic.n_ipaddr;
including the header, ipport.h, then gets you the ip4_addr[1-4] convenience macros... For example, the following should print your attained IP address:
printf("\nIP Address\n%d.%d.%d.%d\n",        ip4_addr1(*ipaddr),        ip4_addr2(*ipaddr),        ip4_addr3(*ipaddr),        ip4_addr4(*ipaddr));
NOTE: You could also do the same thing with nets, I believe, though I've not tried that.
Cheers,
- slacker
Hi Slacker,
Firstly, thanks for the fast answer.
I had success with the nets data structure.
ip_addr my_ip_addr;
my_ip_addr = nets[0]->n_ipaddr;# #############################
For the netstatic data structure, it was undeclared.
Martin
