12748 Discussions
Running Java on uclinux-nios2 board
I have juat ported K-virtual machine (sun propriety) and am currently running Java programs on NIOSII using uclinux. And it took me no more than 4-5 days. I would just like to thank all the people asnwering questions on this forum.
Cheers,
PS: Should I add a wiki page describing the steps to do this or not.
--- Quote Start ---
originally posted by madman23@Oct 30 2006, 12:18 PM
hello,
      i have juat ported k-virtual machine (sun propriety) and am currently running java programs on niosii using uclinux. and it took me no more than 4-5 days. i would just like to thank all the people asnwering questions on this forum.
cheers,
ps: should i add a wiki page describing the steps to do this or not.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19002)
--- quote end ---
--- Quote End ---
Excellent !
--- Quote Start ---
originally posted by hippo+oct 30 2006, 12:24 am--><div class='quotetop'>quote (hippo @ oct 30 2006, 12:24 am)</div>
--- quote start ---
<!--quotebegin-madman23@Oct 30 2006, 12:18 PM
hello,
cheers,
--- quote end ---
--- Quote End ---
Excellent !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19003)</div>
[/b]
--- Quote End ---
Yes you should add a Wiki about this. Please http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Added the nios-wiki page it describes the basic steps needed to get the java programs running on nios2 using uclinux hopefully they are clear enough
--- Quote Start ---
originally posted by madman23@Oct 29 2006, 11:18 PM
hello,
cheers,
--- quote end ---
--- Quote End ---
Sure, it will be helpfull if you can add some descriptions about those step.
Hopefully will SUN also open-source its JAVA IP including KVM too, as SUN stated some time ago!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19046)</div>
--- Quote End ---
Yep I have added a bit of description as to what all the j2me related steps are supposed to do.
With regards to sun:
I think sun would release the Java j2se etc.. for desktop/server applications as open source. But kvm is really quiet new v1.1 and also it makes no commercial sense in a booming market of embedded systems to open kvm source/ although development can progress faster with it being open source... But thats just my 2cents http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
regards,
hi madman23,
i tried ur wiki recently but i cant find any makefile under ~/download/j2me_cldc/kvm/VmUnix dir. and there already has a makefile in the ~/download/j2me_cldc/kvm/VmUnix/build dir.
there is nth at line 171,172 in runtime_md.c either. the files at sun java site are updated probably?
Pls help. Thx.
may I ask you, where can I download java vritual machine ?
When I find this on nioswiki http://www.nioswiki.com/operatingsystems/uclinux/running_java_on_uclinux-niosii_board
and try link:
http://www.sun.com/software/communitysource/j2me/cldc/download.xml (http://www.sun.com/software/communitysource/j2me/cldc/download.xml
it switch me to http://www.sun.com/software/opensource/index.jsp
and I am not able to download java virtual machine.
Could you advice me ?
Thank you very much.
Jan Naceradsky, Czech Republic
I found this:
http://hg.openjdk.java.net/
Is this not the appropriate page ?
-Michael
I am not sure, I can not find the download of java virtual machine ...
but in distribution of uClinux I found the Javm directory, isn¨t it, what i am finding ?
Jan Naceradsky
Hi all,
I have the same problem.
It seems to be deprecated, and replaced by CLDC HotSpot Implementation. But i don't understand what to do with it, and i don't know where to download it too !!!
By the way, i would like to thank all of team who write the niosWiki. It's a pity that it's not maintained.
Anyone knows how to run a java program on a niosII µClinux, with or without KVM ?
Hmm, i try to compile the kernel with JavaVM, but it finishedd with error.
Could you tell me, where is error or is anybody who has the kernel uClinux with Java VM ?
If you don't give us errors, we can't help you.
But, i think JVM is not runnable on a µClinux because it's too heavy for this embedded OS. It's for this reason that we must install KVM.
This is what i've understood, but i'm not sure.
