SOPC Avalon Timing
Hi ,
When I add a component to my system using SOPC Builder , I am not sure of what values I should enter for Avalon Timing (Setup , Read Wait , Write Wait , Hold , Read latency).
How can I determine the exact values for these parameters ?
Thank you,
Quan
hello quan1328
first it depends if it's an external component.
if yes, then you must have a look into the datasheet and timing
for this component.
if it is an internal component, then you determine the timing with your
vhdl or verilog code.
for internal components, i use the waitrequest avalon signal to handle
the timing. then you don't have to enter the avalon timing values.
e.g. reading a register from an internal component requires e.g. 1 clock cycle,
while reading from a fifo or other ram component normally needs 2 or 3
clock cycles.
see 3.2.2 Slave Read Transfer, Wait states
http://altera.com/literature/manual/mnl_avalon_spec.pdf (http://altera.com/literature/manual/mnl_avalon_spec.pdf)
--- Quote Start ---
originally posted by fischer@Aug 17 2006, 11:32 PM
hello quan1328
for this component.
clock cycles.
see 3.2.2 slave read transfer, wait states
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17685)
--- quote end ---
--- Quote End ---
Hi Fischer,
I am reading the pdf you suggested .
Thank you very much,
Quan
