Annonces
Why linux did not boot?
Contributeur émérite II
1 414 Visites
Hi all,
After I "make linux image" in red hat linux,I download the zImage to the ram of my custom board with the command "nios2-download zImage" in the Nios2 Command Shell.
When I run "nios2-terminal" in the Nios2 Command Shell, the linux did not boot,why?
Please tell me how to do? The following is the message:
. Removing old PATH, because a copy of
. cygwin1.dll was found at:
. /usr/bin/cygwin1.dll
. You can remove or rename it to avoid conflict.
Welcome To Altera SOPC Builder
Version 6.0, Built Fri Jun 16 08:10:03 PDT 2006
Welcome to the Nios II Embedded Design Suite
Version 6.0, Built Fri Apr 21 04:12:54 PDT 2006
Example designs can be found in
/cygdrive/e/altera/examples
(Executing user startup script: e:/altera/user.bashrc)
Microtronix Linux Extensions
Version 1.4, Built June 20, 2005
[SOPC Builder]$ cd ..
/cygdrive/e/altera
/cygdrive/e
[SOPC Builder]$ cd zImage_
/cygdrive/e/zImage_
[SOPC Builder]$ ls
nios2.ptf zImage
/cygdrive/e/zImage_
[SOPC Builder]$ nios2-download zImage
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: OK
Initializing CPU cache (if present)
OK
Downloaded 722KB in 17.3s (41.7KB/s)
Verified OK
Leaving target processor paused
/cygdrive/e/zImage_
[SOPC Builder]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems. You may experience intermittent JTAG communication
nios2-terminal: failures with this cable. Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable. Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
0 Compliments
1 Répondre
530 Visites
Finally,I add -g after nios2-download,then it is ok. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
0 Compliments
Répondre
