12745 Discussions
SRAM interface timing parameters
I'm currently setting up my NIOSII system on my own board.
I've done some measurements on the SRAM_nCS, SDRAM_nWE... signals.
I find the timing a little bit too tight.
It seems like it is not possible to change this in the SOPC builder??
How can I modify these timings?
Kind regards,
nvdb
Please clarify: SRAM or SDRAM?
oeps,
it's sram and NOT SDRAM; signals should be SRAM_nCS, SRAM_nWE...
Kind regards,
nvdb
Here's what I got from one of the developers. Please tell me if it helps you solve your problem...
The default dev kit SRAM component (two IDT71V416 chips, normally appearing as 'ext_ram' in example designs) should automatically compensate for timing by adding appropriate Avalon wait states depending on the desired System Clock Frequency.
Internal memories do not compensate in the same way; other external memories require their own class.ptf files to configure their timing requirements.
You cannot modify the timing settings of the default component -- it does all the math for you, based on System Clock and it's class.ptf settings.
There are 3 sets of settings (wait states & setup/hold times), for the following frequency ranges:
{f <= 50MHz}
{50MHz < f <= 100MHz}
{f > 100MHz}
To get different setting requires making your own component/class.ptf, or hand editing the system.ptf.
Thanks for your reply! This was the answer for my question; I&#39;ve tried it in hardware and it&#39;s working.
Bye.
Great!
Happy NiosII-ing http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
