- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I'm currently trying to initialize a semaphore by making a call to sem_init(), but instead of returning a non-zero value and printing a error condition, Nios II reboots.struct sem_t *msem
if (sem_init(msem, 0, 0) != 0)
printf("Semaphore not initialized\n");
Is there something specific that needs to be configured in the kernel that provides support for semaphores? Any feedback would be appreciated.
Link kopiert
5 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi bjskill,
The sem_init() routine initializes the semaphore object that the first argument points to. So you're passing in an un-initialized pointer ... and something ends up getting trashed. Try: /*struct sem_t *msem */ struct sem_t msem /*if (sem_init(msem, 0, 0) != 0)*/ if (sem_init (&msem, 0, 0) != 0) printf("Semaphore not initialized\n"); Regards, --Scott- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi smcnutt,
I made some errors when I made my original post. When SemInit() is called something seems to get trashed and cause Nios to reboot:SemInit(myThreadName, &mySem, "mySemaphore");
void SemInit(char *who, sem_t *mSem, char *label)
printf("%s is initializing %s\n", who, label); // Debug message
if (sem_init(mSem, 0, 0) != 0)
printf("Failed when initializing semaphore.\n"); // Error message
printf("%s has initialized %s\n", who, label); // Debug message
return;
I don't see either the debug or error messages displayed before the reboot. Thanks for your help.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I'm not sure if this is the problem, but you may need to turn on IPC support in the kernel in order for semaphore support to work.
Take a look at: .../altera/kits/nios2/examples/software/linux/apps/samples/thread for an example of semaphores...- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Ken,
I think that might be the problem. However, I only get an "undefined reference to 'sem_init'" error from the linker when DEBUG=1 and it attempts to generate the .gdb file. When DEBUG=0, the linker does not report any errors or warnings when it generates the application. What path do I need to follow within the kernel configuration menu to check and see if IPC support is turned on? The only choice in the menu options that I found that was related to semaphores is "General Setup --> POSIX message queues". Is that right? I'll also take a look at those linux examples to make sure I'm initializing the semaphores correctly. Thanks for your help. UPDATE: (8/24/05): I enabled the "General Setup -> POSIX message queues" from the kernel configuration menu, performed a new build, and downloaded the new vmlinux.bin file. However, the application still causes a Nios2 reboot as soon as sem_init() is called. Is there something else I'm missing?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Sorry for the late reply, how about you post your full code and I'll run it on my board to see what happens?
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
