I would like to use SharedLibs in MicroWindows Librairies options, but during the compilation I had this error: <div class='codetop'>CODE</div><div class='codemain' style='height:200px;white-space:pre;overflow:auto'>/opt/nios2/bin/nios2-linux-uclibc-ld.real: -shared not supported</div> Why? What is the solution? Thanks for your help. ChrisLink Copied
The current "NIOS2nommu" architecture does not support shared libraries. The upcoming MMU-enabled full-Linux "NIOS2" architecture will support shared libraries.
But anyway, I am happily using NANO-X without shared libraries. -Michael- Mark as New
Thanks Michael.
Other question, is it possible to have a web browser with only 16MB RAM memory? Because when I start uClinux, I have only 8MB free memory and Links doesn't start. (page allocation problem) And when I use a small zImage (without graphics drivers for exemple) I have 10MB free memory, I can start Links but when I want open an url, I have a problem => ERROR: out of memory... Thanks Chris- Mark as New
I suppose you are speaking of a graphical web browser. A text based browser should be no problem, but graphical: I don't know.
Ok, now, browser Links starts in text mode without problems.
But in graphical mode, I had a problem with DirectFB lib <div class='codetop'>CODE</div><div class='codemain' style='height:200px;white-space:pre;overflow:auto'> > links -g ~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.2.3 |~~~~~~~~~~~~~~~~~~~~~~~~~~ © 2001-2008 The world wide DirectFB Open Source Community © 2000-2004 Convergence (integrated media) GmbH ---------------------------------------------------------------- (*) DirectFB/Core: Single Application Core. (2009-07-08 08:37) (!) DirectFB/core/system: No system found! Could not initialize any graphics driver. Tried the following drivers: directfb: No (suitable) implementation found!</div> Did you have this problem Michael? Thanks for your help Chris- Mark as New
Right now I am working on another branch (without a framebuffer enabled), so I can't check into this easily. I'll do so when this branch is successfully finished.
I seem to remember that there had been a discussion on DirectFB, here, but, alas, all seems to be lost.... -Michael
Topic Options
