Simulating NiosII in Modelsim
I'am simulating a small Nios II System in with Modelsim.
After starting the Simulator from the Eclipse,
I use the command "s" in Modelsim to compile all HDL source code and to load the design.
I use the command "w" to open the Wave window with "useful" signals.
Now i can run my Design.
My Question:
What should i do to see the "OpCode" and the Nios Pipeline structure in Modelsim, like in the attached File ?
Nicolas
