Superloop with LAN91C111
I would like to use Superloop mode of InterNiche stack on my board with StratixII EP2S60 with LAN91C111 PHY\MAC Controller. I use the Quartus II 9.0.
Following steps (mention in thread: Altera Forums > Device and Tools Related > FPGA, Hardcopy, and CPLD Discussion - I cant post the regular link )
1) Copy drivers files in (C:\altera\90\ip\sopc_builder_ip\altera_avalon_lan9 1c111\UCOSII) from UCOSII to HAL
2) Edit component.mk to refer to the HAL
3) Enable auto initialize the driver in alt_sys_init(), by set "set_sw_property auto_initialize" on true in the file altera_avalon_lan91c111_hal_sw.tcl
4) Remove specific code that refers to unused hardware component - like TSE, LCD
5) Compile project
But I have the problem with enable driver for the LAN91C111 interface. I got following errors:
--- Quote Start ---
prepared 0 interfaces, initializing...
inet startup error: unable to find any working interfaces
dtrap - needs breakpoint
panic: IP
--- Quote End ---
Could anybody help me to figure out this problem?
