公告
12748 討論
Tri_state_bridge not reading data bits [31..16] from SRAM
榮譽貢獻者 II
1,139 檢視
I have a custom board based on the Cyclone III FPGA Starter Kit.
We have recently added SRAM using the IS61LP6432A, a 32 bit device.
In SOPC Builder there is a tri-state bridge which connects the SRAM (CY7C1380C Component) and CFI flash to the NIOS processor.
The tri-state bridge component is configured for the address lines being shared.
The CFI Flash is a 16 bit device which shares its address and data lines with the SRAM. The top 16 data bits of the SRAM are not shared.
In the top level FPGA design:
SRAM_DATA[31..16] is connected to tri_state_bridge_data[31..16]
FLASH_DATA[15..0] is connected to tri_state_bridge_data[15..0]
FLASH_ADDR[22..0] is connected to tri_state_bridge_address[23..1]
The bottom 16 bits are being handled as expected, but when my NIOS program reads 32 bits from SRAM the top 16 bits are always FFFF.
Strangely, when checking the SRAM signals on a scope the data agrees with what was written into the SRAM by NIOS. :confused:
0 積分
2 回應
榮譽貢獻者 II
383 檢視
Check that the byte enable signals are connected properly, and check the pin assignments. I know that in the Cyclone 3 development kit, some pins for the SRAM are wrong in the documentation and the reference designs. It could be the same with the starter kit.
榮譽貢獻者 II
383 檢視
I tried changing the SOPC CFI flash component to 32-bit to see what would happen. This was even worse, as NIOS Flash Programmer couldn't access the CFI device.
I backed out of the changes and then discovered that my problem had gone away. I've no idea what changed. I'm now using the same .sof file as before and 32-bit accesses are working.
It's as if there was a dependency which was being ignored and my reversion gave it a nudge in the right direction :)
Then (before Daixiwen's reply) I ran the altera memtest and found 3 wrong pin assignments. This was partly due to using the reference design. So it's a respin of the PCB. :(
回覆
