Hi Folks-
I have a Verlog delay line module that seems straightforward and seems to work when I simulate it using ModelSim and when realized on my Cyclone II FPGA. I always get warning 13310 for every bit in the delay line array:
Warning (13310): Register "MPS_SOPC:inst|pulse_engine_0:the_pulse_engine_0|pulse_engine:pulse_engine_0|sample_delay:delay|mem" is converted into an equivalent circuit using register "MPS_SOPC:inst|pulse_engine_0:the_pulse_engine_0|pulse_engine:pulse_engine_0|sample_delay:delay|mem~_emulated" and latch "MPS_SOPC:inst|pulse_engine_0:the_pulse_engine_0|pulse_engine:pulse_engine_0|sample_delay:delay|mem~latch"
Can anyone tell me what I can do to resolve this warning? Is this warning significant? Here's the HDL code:
`define BUFFER_SIZE 64
module sample_delay(
input wire reset_n, // Reset
input wire adc_clock, // Sample clock
input wire adc_data, // Input sample
output wire adc_data_delayed // Delayed sample
reg mem;
integer i;
initial
begin
for(i = 0; i < `BUFFER_SIZE; i = i + 1) mem = 14'd0;
end
assign adc_data_delayed = mem;
always @(posedge adc_clock or negedge reset_n)
begin
if(~reset_n)
begin
for(i = 0; i < `BUFFER_SIZE; i = i + 1) mem <= adc_data;
end
else
begin
mem <= adc_data; // <--- COMPLAINS HERE AND NEXT LINE
for(i = 1; i < `BUFFER_SIZE; i = i + 1) mem <= mem;
end
end
endmodule
Thanks for the help. John Speth
curious why reset sets all registers to adc_data instead of 0. Cyclone II doesn't have both async preset and reset. changing adc_data to 14'd0 will suppress the warning
i think the power-up values from the initial block disagree with the values from your reset, causing the latch. this is why changing the reset values from adc_data to 0 fixes the issue
Apart from what's already said, your design forces the compiler to use a huge amount of logic cells for the delay array. By restructuring the code in an intelligent way, it can be realized as circular buffer in embedded dual-port RAM. The shift register MegaFunction does just this.
i can do this
--- Quote Start --- i think the power-up values from the initial block disagree with the values from your reset, causing the latch. this is why changing the reset values from adc_data to 0 fixes the issue --- Quote End --- Thanks. That was the key to making the warnings go away. I'm amazed at the deductions that Quartus is making when it analyzes the HDL code. I wonder if it ever misses the intent. My inexperience is obviously exposed. It's such a complex tool and there is clearly no substitute for experience and knowledge. I hope to acquire both over the years. Thanks to everyone for your opinions and help. JJS
Maybe sligthly Off Topic but I strongly disagree with the use of the "initial" statement for synthesizable designs.
Don't you think this is a dangerous way of describing circuits?- Mark as New
--- Quote Start --- Maybe sligthly Off Topic but I strongly disagree with the use of the "initial" statement for synthesizable designs. Don't you think this is a dangerous way of describing circuits? --- Quote End --- I half agree with you. Before I started this thread, I was told by a local expert (and believed it) that the "initial" statement was not synthesizable but useful for simulation. Based on that understanding, I leave the "initial" statements in so I can resimulate if necessary. I assumed it had no effect on synthesis. The comments in this thread have shown me that the "initial" statement does have some indirect bearing on how the tool behaves. It might not make a bit of difference in the final synthesized output though. I have no idea how to prove or disprove that. JJS
