12745 Discussions
StratixIII dsp board uclinux tse driver
Dear all,
I'm having trouble with uclinux on a StratixIII Altera dsp board. The system boots correctly but, when I try to start the network, it does not work. I tried both sls and tripple speed ethernet driver without success. Have you a working Altera project with the network (and in case the corrected driver)?
Marco.
Make sure you also select the correct PHY driver for that board.
